ShellsterT
- Aug 2, 2012
- 1
We recently purchased and old boat and motor. The owner said everything worked great. When he turned the motor over it popped right off. When the motor is in the water it idles great until you put it into gear, then it boggs down and dies. We have had the plugs changed, carbs cleaned, head gasket replaced and some other things. Everything has tested out great. Took it to the lake again. This time it doesn't completely die, but there isn't much power. What should we check/do next?
