Just recieved a new solenoind ( from Iboat) for my motor size wise the part looks similar. The bracket that held the old solenoid to the engine block does not look like it will hold the new part? The new part has a bracket already attached to the solenoid. I do not think it will mount into the same location as the old one?
My question is can it be moved to a different location as far as mounting it to the motor? The part number of the replacement is Sierra 18-5807. Package says it replaces OMC 378444 Prestolite SAW4206. If I could remove the bracket on the new solenoid it may fit into the exsisting holding bracket. Any help here would be great.
