nwcove
- May 16, 2011
- 6,293
just started work on a 4hp johnson deluxe thats been sitting in a basement for years, the only way i can get it to run is to squirt premix into the carb. the owner said it was fogged before storage, and the carb is covered with about 1/8" of yellow goo, which is also under the carb. i have fogged a few and never have made this yellow mess? could this "stuff" be the cause of the engine not getting fuel? ie, hs jet clogged? ( fuel is getting to the bowl)
