tach for 15hp evinrude
Baby Blue
Does anyone know if I could wire an in dash tach for a 1992 15HP evinrude? I do have a charging system on it but it's pull start.
I heard that you may be able to connect to the yellow wire on the stator?
thanks for any input.
BB>
Baby Blue
Re: tach for 15hp evinrude
Here is a photo of the recifier. any help out there?
BB>
B-Dozer
Does the motor have tilt/trim ? or are you trying to prop it ? If not you really dont need a tach for a small motor.
Baby Blue
no tilt or trim. Yes.. I'm trying to prop it. It is possible with a standard tach (not minitach).
Just need wiring instructions if possible.
thanks, BB>
jauguston
I use a Tiny Tach on my 92 15 hp.. I am now using it on a 91 30 hp. Both Evinrude.
F_R
Of course you can use a regular alternator driven tach on it (the industry standard). Connect to one of the yellow wires and ground. You will also need a 12V battery to power it. I believe it is 5 pulses per rev (10 pole).
nwcove
jaug......babyblue hasnt been active on the forum for 2.5 years.
