hi all,
ive read, read some more, and read till ive fallen alseep trying to find an answer to my engine problem.
here goes...
recently bought a be70elcca engine which was in storage for a while, it was easy to start on muffs and idled ok ish.
took it too the water and would not start, (back pressure i assume) we eventfully did start it after putting a little premix down cylinder 2. it started and idled fine. took it for a run and went ok but bogged and lost power intermittently, finally cutting out.
we repeated this process for a good 4-5 times, even let it sit idling for 15 mins and seemed ok, another run and the same thing happened. we came to the conclusion that the carbs need cleaning.
back home we stripped carbs, cleaned all jets (not much crap in there really) and checked float needles and float height, all ok. cleaned them all with carb spray cleaner and very happy with the result.
all ok and clean we refitted it all together.
started 1st crank, now it idles like crazy (but no missing or sneezing) if it were throttled up id say it was perfect running.
but its not, it is idling way way too high, only retarding the timing as far as it can go will it idle low enough that im happy with it.
i have disconnected the cam follower so i know all the butterflies are fully closed.
its pre set mixture with no adjustment screw.
it has the primer solinoid, it used to need manual setting to fire before we took it to the water, but now it doesnt and moving to auto or manuel does nothing.
ive pulled the fuel pump off (not opened it up) and can gently blow and suck the pulse inlet and i can sense the diaphram going open and closed with no leak. it also pumps enough when cranking the engine (we had a clear pipe on it to test.
im running out of ideas now as to what to check, when it did run on the water and behave it was great! now cant get the racing (although smooth racing) idle to come down
plugs were fairly oily when we first got it, now i think its lean as f... the plugs have very little oil on them and when running it is not smoking very much at all. fresh fuel at 50:1 mix as the manual.
sparks all good, flywheel not sheared/spun. TDC is spot on.
here goes...
