nite fisherman
- Jul 14, 2011
- 33
I am in the process of replacing the transom on my Starcraft. I have disconnected all motor connections except the steering cable. Can someone tell me if I only have to remove the big nut on the right side of the motor around the steering cable, which goes back to the steering wheel. I have removed the linkage rod on the left side of the motor. I backed the nut off all the way and the linkage is sliding but was wondering about the 4 smaller bolts, 2 on each side of the trim and tilt pivot hinge. Any help will be greatly appreciated.
Nite fisherman.
Nite fisherman.
