Hi all, Have 1999 Johnson 150 J150PLEES that was overheating... replaced stats,still overheat. I removed stats and ran on hose for 10-15 minutes and could keep my hand on both heads without burning. Also removed stat covers and started motor to see water flow and all is good.While running on hose,there is warm/hot exhaust water coming out in front of lower unit by shift shaft and the mid section cowling is very warm to the touch.
I did notice a big difference in tell tale water...with stats removed the pressure is next to nothing coming out(peeing).
Today I installed complete water pump kit, made sure water tube was lined up, still have overheat problem. When lower unit was off, I took hose to water tube and got good circulation up above thru powerhead.
What am I not seeing or have overlooked? Thanks
