just rebuilt a 110 evinrude and I removed the vro system so I broke the engine in on 36-1 oil. I also installed boyseen reeds during the install and the roller that was in the slot for the timing lever seemed to have either wore down or the outer part,if there was one was gone so I picked up a roller from a hardware store to take up some slop. Does this motor have alot of slop between the roller and slot or not???? Also I had a miss at wide open throttle and found one of the wires were bad so ordered new ones and they are the ones you have to put together. Does anyone make premade wires that are 9 inches long??? the ones I got I had to put the end on.....And I am running non ethenol gas and tried the gapless plugs but have not had good luck with them. Are they anygood/????
Thanks for any and all responces...Gary
