Re: OMC side mount Control Question Backwards
Thanks everyone for the help i do have the cables connected correctly now i just need to find out why i can't get it to return back to idle without manually pushing it against the block.I read where you adjust the cable to the motor and not the motor to the cable but i just can't adjust the thing correctly when i move the control forward and then back to neutral.I always seem to have about a 1/4 inch spacing no matter how i adjust the cable it always idles about 200-300 rpm higher.
I am wondering with the spark advance or something is sticking and not allowing it to return to idle via the control.Not sure if its the control,cable or an adjustment that needs to be made on the motor.
