Hello all,
I have a 93 Johnson 60hp Outboard, 3 cylinders, 2 cycle.
My Question is does this model have a charging system?
If so where would I find it? I don?t think it would be an ?alternator?
The Issue and/or Concern:
At low trolling speeds it voltage reads around 10v
At higher rpm?s /full throttle it will read 12v (think?? trying to recall)
Is this normal?
I have to charge it after a day on the lake, because the one battery runs everything; motor starting,
Tilt, trim, bilge, live well, lights, gps, sonar, and a couple other accessories
Thanks Craig
Is this normal?
Thanks Craig
