TampaNate77
- Jun 6, 2012
- 117
So I went to take my carbs apart to rebuild because the motor was running like it was loosing power when I throttled it up. So when I took the carbs off and apart the bottom Carb was missing the spring that holds the needle seat. And that is the cylinder that is off by 5 Psi compression. Can that be the reason for the compression to be off?
