This is my first outboard, but I do know there should be a tell tale stream of water from the lower shroud. Not in this case. Once I got the boat home first thing I did was replace the impeller and housing. It was not in horrrible shape, but I changed it anyway for piece of mind. The fitting on the port side of the engine where I THINK the tell tale should be connected to has a small hose connected to it that goes to a "water" gauge on the dash. Is this normal for this engine? It is a Pontoon boat and a tell tale would not be readily visible anyway, is this the reason for the gauge?
