Re: Does a 1977 85 hp Evinrude have a tell tale?
You cannot test a water pump by running on muffs. Water would circulate through it even if you completely removed the impeller.
So, with that fact in mind, here is what you should expect while running on muffs. Water should blow out the two holes in the rear of the midsection. It will vary from very little to a spray, according to several variables. Or possibly not at all if running on muffs. But water should be blowing out of the propeller, along with the exhaust. Water will also squirt out a bunch of other various holes in the lower end.
Now: Are you ready to make a meaningful test? Then put the boat in the water and start it up. After a few seconds, you should see a light spray of water coming out those two holes in the rear. That is your "tell tale". The amount of spray varies according to variables including thermostat position, speed, lake temperature, etc. Don't get all hung up worrying about it.
