Sportfisherman 2100
- Jul 8, 2012
- 4
Maybe someone can point me the right direction:
My 1989 Evinrude 150 has intermittent Tachometer operation and nothing stellar in the battery voltage meter readings.
I've read a BUNCH of the threads on these two being symptoms of a faulty Rectifier or loose wiring.
A little history: The previous owner had to have the powerhead rebuilt. (not sure what happened)
Current Symptoms:
Engine was a bit hard starting, when it does start and warms up, ran fine. Good Power, top end speed good. Tachometer intermittent. 0 or proper RPM readings but on and off with no pattern or predictability.
I replaced the batterys with heavy duty Marine Batterys (not neverstarts) and am using hex nuts on the terminals.
The warning horn will come on occasionally, if I slow down, it usually goes off. Oil tank is full and water is "peeing" out of the tube and feels warm but not hot to the touch.
Something new yesterday. While under power, (no warning horn or other issues) the engine suddenly slowed down and then stopped. When I started it back up, it ran fine. Fuel pump ball was still pressurized. Ran quite a while, then warning horn. Slowed down, warning horn went off. Picked up speed again and after a bit, engine slowed down and stopped again. Idle is now very rough and starting difficult. High Speed it seems to run ok (and still lots of power till it stops)
Repeated the above several times. Finally, to get back to the launch (about 15 miles) I only accelerated about 1/2 speed and it ran all the way in with no issues.
QUESTIONS: Does the oil injection pumpl run off the tach signal? If so, when there is no signal (ie: Bad Rectifier) would that cause the injection system to not work which in turn sounds the alarm horn? (I have not read this addressed in any of the threads. Just that the alarm may go off if the tach is intermittent, not what the alarm is sensing) IF (shudder) the injection pump is not working, would that cause enough friction to stop the motor? (I'd think the Cyl's would be scored but looking through the spark plug holes with a bore scope (i'm a shooter) they do not look scored) Would a faulty rectifier cause the engine to run rough at idle and slow speeds? Lastly.... How do I tell if the rectifier is a 10am or 35 amp? And... on the 1989, is it located on the block on the left hand side, (boat left hand) or is it under the fly wheel.
OK... Thats it. I do not have a peak voltage meter to do a bunch of Grey / yellow / grayish Yellow / and Yellowish gray wire readings.
THANKS!
Andy
Current Symptoms:
THANKS!
Andy
