reiddo1
- Jan 17, 2012
- 166
My 1979 200 hp evinrude will not turn up more than 4,000 rpm at wot. Butterfly plates in the carbs are straight across at wot, plugs are burning correctly with a tan deposit, and the prop is a 14.25 inch with a 21 pitch, which I believe is one of two props offered for that year. Boat speed at wot is between 54 and 59 kilometers per hour (33 to 37 miles per hour) depending on trim. The boat is a Glastron Sea Fury 216 and I believe should be able to travel at 45 mph at full engine revs which I believe are around 5300 for that engine. Engine starts poorly with electric choke when cold but fires up readily when warm. Any ideas would be welcomed.
