Re: 1993 johnson 48 special reverse lockdown
Had the same issue
Basically the cable housing was cracked, so when you moved the release lever
the cable that releases the pressure valve on the cyclinder was going through the case.
Replaced the cable, and cured the issue.
Now that you have drolled a hole in the cyclinder, that will need to be either replaced, or you may get away
will patching with some JB weld.
Good luck
