1993 johnson 48 special
tiger6
Motor seems to run fine when your running, but it idles rough and dies. Ant ideas? Thanks
Daviet
Re: 1993 johnson 48 special
Compression ok?
Plugs in good shape?
Have you tried adjusting the low speed needle valves?
tiger6
Yes,Yes and no I haven't adjusting the low speed needle valves. Is there just one low speed needle valve or one for each carb?
