I have an issue with the recoil spring carrier housing. I was pulling on my rope and the recoil spring broke. So I ordered a new spring and installed it (After some very bad words, and temper-tantrums) . I installed the carrier, and all of the other mounting extras, and pulled on it. It pulled out about half way and stopped. No rewind, no nothing. I took back off and discovered that the part of the spring that sticks out of the carrier had pulled back into the carrier. I have been fooling with it back and forth and it is the same thing every time. Have I missed something here? I installed spring, and then wrapped the chord around the chord holder. Wrapped it tight. So that when I pull it will tension the spring and recoil it back in.
