Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
1976 25hp Evinrude Foot Leak?????
  • 1976 25hp Evinrude Foot Leak?????
    Jut got my motor running yesterday...Got home today and looked in the tank that I had it in and there was a lot of oil.. Pulled the motor out of the tank and wiped it down and noticed oil coming from a small hole next to the full oil level screw I dont know if this is normal or not and if not can someone tell me how to correct this problem? I took a pic so that you can see
    Re: 1976 25hp Evinrude Foot Leak?????
    Yes, that's normal. That's a drain hole for unburnt fuel.
    '77 Crestliner Voyager Deluxe 16' (semi V), Spartan WondeRoll tilt trailer, '81 Johnson 25 hp, '88 Johnson 30 hp, '87 Evinrude 30 hp
    • #3
      Thanks... it had me worried
      • #4
        +1. Just unburnt fuel/oil mixed with water and exhaust. If it becomes excessive you may only be running on one cylinder, but it looks ok for now. You can either wipe it up, or place a paper plate under the motor to catch the drips. If there was water intrusion into the gearcase as your gear oil would be sort of a milky white/yellow color.
        Back to Top
