LOSTBOATER72
- Jul 6, 2001
- 47
I just finished replacing the waterpump/impeller on my 72 Johnson and went to put the lower unit back in and found that I need to have someone to turn the flywheel to match the splines on the driveshaft to get it back in. That seems simple enough. My concern is connecting the water tubes from the upper unit into the water pump on the lower unit. It seems there is no easy way to do it. Any thoughts or suggestions would be very helpful.
Thanks all for your time!
Sincerely,
LostBoater72
Sincerely,
LostBoater72
