gamespanker
- Aug 1, 2011
- 9
First, let me say that I do not know much about boats.
I noticed that I had a little oil in the bottom when I take cowling off. I took off the "air silencer assembly" any was able to tell that the oil was coming from the carburetors (I guess that is the air intake portion of the carbs).
Also, it should be noted that my oil pump has been removed and I mix the oil with the gas, but this is kind of green and very thick, like oil you would put in your car. Anyone have in ideas?
Also, the boat dies very easy. When I first start it in the morning, if fires right up, but as they day goes on, it runs worse, It will idle in neutral and what I go to take off it dies.
I should also point out that it gets run at low speeds a lot because a lake I like to fish is no wake.
Thanks for any help.
