Hey ya'll I've got a 75 hp '63 Johnson motor, model number V4S-12 on '60 Larson V Haul.
So I got new plugs and wires in and then it started to rain, so I left my boat in the shade (not where I normally do) and when I can back out the next day, I just happened to pick up the ignition box and water just SPEWED out of the box. So I was like 'damn thats not good. :facepalm:' My only guess is that where I had the boat there is a small really unnoticeable down hill to the ignition box side so the water filled up there faster than it could drain out. So I took apart the ignition box and found both of my fuses were blown out, so I got new ones of those and still nothing happens when I turn the key. So my question is what do I need to check/probably get a new one of, since before this happened everything worked up to 'no start part'.
Any help on this would be great and apprenticed very much, I hope to have this out on the water by the end of this month hopefully.
