Re: Battery hookup to johnson motor
He should trace the battery cables to the motor. The positive cable will normally go to the starter solenoid. The negative cable will be grounded to the block, possibly near or at the starter solenoid. Also, normally battery cables are red for positive and black for negative. If he has two blacl ones, after you figure out which is the positive cable, wrap some red tape around it for the next time.
