JTKelleyiii
- Feb 19, 2012
- 49
I have a 1975 135Hp Johnson, model 135ETL75E.
Recently, the clutch dog will pop sometimes when I am shifting into Forward.
It does not do this all the time. Following one of the popping episodes, once it gets in gear and stays there it runs without issue all the way up to 5000 rpm.
I have looked through my service manual, Johnson, and it does not shed much light on this situation.
My questions to you professionals are:
- Is this an indication of the clutch dog starting to go out?
- Seems to me if the dog was going it would pop out at high rpm, high torques scenarios, which it is not.
- Could this simply be a cable adjustment since when it occurs is when I am shifting into forward at low rpm? If so, any advice on this? The manual is not really helping me, maybe I just have not found the info yet.
Any thoughts would be appreciated.
Thank You,
John
Thank You,
John
