Hi,
I'm having some problems getting this old engine to run properly.
It only starts when I put it on "fast" speed. And then it runs for a few seconds and when it tends to die. It helps pulling out the chocke and push it back in instantly.
I also got it to run with the chocke "halfway" for a good 10 minutes or so at the lake, right now I run it in a barrel again.
I have cleaned the carburator twice, but I have no idea on how to tune this carburator.
It doesn't have a high-speed needle at front which I find on all diagrams.
And the low adjustment on the front doesn't seem to change anything..
The fuel-line is made of copper and is leaking when I open it up. Could this be my problem?
I also pulled pretty much the entire motor apart and cleaned it.
The gaskets where a bit dry aswell :/
I'm thinking of buying some sort of kit for it. Only one problem,
I live in Sweden and parts are really hard to get.
Any ideas are apperciated, I can't really afford to get a new engine.
Best regards
Best regards
