FrankBama
- May 26, 2009
- 7
I had to replace the inline fuse on my outboard today and having an issue making the new fuse fit? I purchased a standard ANCOR 20 amp 1 1/4" long fuse which works, but seems to be too long for the rubber casing? It does not allow the two pieces to come fully together and seal. The fuse I replaced was cracked in half so I am not sure what was in there before but the casing was definitely closed and sealed properly when I opened it originally. Anyone know where I can find the manufacturer's specs for this fuse? I know ANCOR makes a GMA line which is like an 1 inch long but the highest amperage they have is 15.
