Sureshot
- Sep 28, 2011
- 97
Hey everybody,
I rebuilt my Johnson 2000 50 HP (J50PLSSM) over the winter and it's been running great... Almost. I have to push the throttle pretty far forward when I shift into forward gear. The idle RPM's in forward gear should be 800 or so but on my tach they barely register 200 - 500. Carbs were cleaned and rebuilt, mixture screws set to 3.5 (suggested by manual). I've moved the idle set screw all the way forward but doesn't seem to make a difference. Should the engine reach 800 RPM with the carb throttle plates closed? Meaning, should the timing advance be all that controls the idle speed? Do the mixture screws help raise the RPM's? Feel like I'm kind of chasing my tail at this point. Engine runs great mid range and higher speeds. Any suggestions would be appreciated.
