markngeorgie
- Jun 28, 2012
- 1
Tilt worked fine until running into a shoal at low speed, had to bleed plug to release to tow. Trying to fill and bleed air, two small pistons go up and down independently, main piston is up but wont go all up to release latch, if I run small pistons down a little, there is some give when pressure is applied to them. Thank you as I know little
