decdrummer
- Jun 7, 2011
- 22
Hello all! I have a quick question. Motor is a 1965 Evinrude Sportfour.
Motor is finally running smooth, however it is only shifting into Neutral and Reverse, can't get it to shift into Forward gear while motor is running, the gears sound as if they are grinding when I try and shift it (lower unit got rebuilt and resealed a few months ago). When I shift it to forward with the motor off, the prop turns clockwise and I hear the motor coughing(?) so it's going into gear when the motor is off, but not enough it seems to drive.
I have disconnected my shift cable and am manually shifting the motor from the gearshift lever on the starboard side of the motor.
I am wondering if any of you can help me with this issue, it seems as if it's just a micro adjustment on the gearshifter, but I need some insight.
Thanks for the help!
