I need some help folks..... I have a 1981 Johnson 35 with electric remote start. The motor starts like a champ but when and only when the motor is running it is backfeeding a helluva current through the remote start box. Everything on it will shock the fire out of me except the shift lever. I have traced every single wire for breaks or worn spots, all good. I have checked every connection, every ground, all good. Everything I have done has not helped any. Today I was checking to see what was hot with a test light, had it grounded to the remote start box and touched the outside of the motor and killed the motor, just like it would if you grounded out the spark plug. Im rackin' my brain and I have no idea what else to do or check. If anybody has any ideas I sure would appreciate them!
