I've done my homework and I understand that the Ficht technology was raw in these motors and that some of you guys steer clear of them with good reason. That having been said, I've wanted one just about since they came out when I was first into boating...seemed like a challenge and great when they run well. Anyway, bought a salvage one from a local outboard guy, has good spark, starts, compression is 125 and up and all within 5-10%, the price was right so I figured this was my chance. Anyway, it looks like the heads are the old, non pinned style. I've heard mixed opinions as to whether or not it's really worth it to upgrade to the deflector pins in a well running engine of that age with a normal amount of hours. What do you guys think? Also, I'm aware of how important indexing spark plugs and using the correct ones is for these engines....assuming I chose to keep the non pinned original heads, is there any reference point for indexing? I'm also aware that they are sensitive to correct propping, what WOT range should I aim for? If it matters, this is part of an effort to restore an old Critchfield that belonged to my grandfather and add modern power. Boat is 20' LOA and with the old engine (Johnson 175 crossflow-mid 80s vintage) would touch the low to mid 50mph range when that engine was fresh and even mid 40s by the time my brother and I got it when it was tired. I know it needs new spark plugs and a water pump, and I want to get the software (Read Only) does anyone know a BRP part # for that I should give my dealer or should I just ask them about it? I remember reading here that the 20" 98 Fichts require a different water pump than the 25", which kit do I need for this 20" Intruder? Thanks...and go easy on me please! My Ficht knowledge is only enough to be dangerous, but I'm ready to be patient with it and learn. Thanks so much
JD
JD
