theplanedo
- May 24, 2012
- 5
Evinrude 15HP 1988 rope "how to install regulator/rectifier?" wich wires to where?
Hi,
I have sonar, battery, lighter plug and 2 25w lights and I am planning to to get electrics from my motor. I've read wiring diagrams and still not convinced how should I plug the wires. regulator/rectifier looks like this:
http://koti.phnet.fi/planedo/kuvat/regulator rectifier.jpg
red=positive +
green=negative -
3 yellows = AC ~
motors port side has AC output for the lights (three pin connect), I'm planning to get direct current out from there. I hope this is possible. If this is possible should the positive battery wire go straight from regulator/rectifier to battery ?
here is motor wiring:
http://koti.phnet.fi/planedo/kuvat/electrical_manual1.gif
thanks
-Janne
Hi,
red=positive +
green=negative -
3 yellows = AC ~
thanks
-Janne
