elkriverangler
- Jun 19, 2012
- 3
I need to know what the wiring hookup is for a Johnson 1977,75 horse,3 cylinder tach.The tach is on the boat it just needs wiring.Thanks..
How many wires are leading from the tachometer and what are the colors of the wires?
If there are no wires leading from the tachometer, there will be terminals on the tachometer and if so, what are those terminals marked?
Gray Wire is the sensor lead. There should be a Gray wire leading from the wiring harness that leads from the engine to the control area. It would connect to that.
Purple Wire is the voltage lead (12v) and would connect to the "A" terminal of the ignition switch
Black Wire is a ground wire and simply connects to any good known ground. DO NOT connect that tachometer ground wire to either of the "M" terminals of the ignition switch as that will invite tachometer and ignition problems!
Where do i mount the spark cable 1- 2- 3 on the strator. and on witch selynder ??
i kant figure out hvere to put new tread sorry !!
