I have a 2002 Johnson 115 2 stroke outboard and the starter is just spinning no engaging(it sounds like something lose also). The battery is at full charge and my connections are clean. Is the starter on this motor a separate piece from the Bendix? Do you have to remove the entire plastic cover over the flywheel to access the starter, because I cannot see the top of the starter? Or does the starter drop down? And if you drop down does the bendex come down also? I looked all over the internet and can't fond any information on the is removal. Thanks in advance.
