Groupergulper
- Aug 21, 2009
- 73
i have recently bought a 1991 19' center console Proline. It has an older 1988 Johnson 110. it overheats at high rpm. with 3 people in the boat it will run 4300 all day long and not overheat, bump it up to anything over 4500 the alarm goes off. I replaced the thermostats and it didnt seem to help. I do not know how old the impeller is but it seems to pump very well, always a steady stream. I will be replacing it soon. I have searched on here for similiar problems , it sounds like it could be the water deflectors. I am going to pull it apart and replace them. Is there anything else i need to do while im in there besides cleaning, scraping, change water deflectors, new head gaskets, water jacket gaskets. is there any modifications i should do?
