I'm rebuilding the motor in the title, and the recoil spring broke. Currently, I have the recoil starter assembly off the motor and winding the rope around the flywheel to start. That's ok, but I'd prefer to use the original assembly. I have two questions.
1. Does anyone know where I can purchase a replacement spring?
2. Failing that, has anyone fashioned a workable spring from an old broken one? This one is broken right at the end where it slips around the pin, and I wondered if it was worth heating the spring with a torch and bending it into the right curve.
Thanks in advance.
Thanks in advance.
