Huskerpower24
- Jun 13, 2012
- 28
I have a 1977 Evinrude 75 hp. I can not get the Power Pilot shifter into reverse. It worked fine one day and not the next. I disconnected the linkage at the engine, and it would engage both forward and reverse fine. It will not go into reverse with the power pilot. I took apart the Power Pilot and everything appears to look ok. Cables move fine from either end. Any ideas???? Please Help! Thank you.
