bscappell
- Mar 29, 2010
- 132
ok so here is what im dealing with http://forums.iboats.com/showthread.php?t=554613
I Synch and Linked my Carbs, adjusted the Cam Follower, did the Joe Reeves timing and the cam follower timing (on the muffs, i don't think that makes a difference?) the only thing i had to change was the cam follower timing.
It seemed to run fine on the muffs but once i put it in the water the start-up idle was ruff and hard to start then would not even stay running without pulling the linkage to the timer base again. so effectively no change.
seemed like the idle was set too low so i turned it way up and it would stay running and go into gear but would die when the throttle was increased in gear.
Ideas? Im about to give up and bring it to a mechanic but god knows how much they would want for a tune up.
