catfishjoe
- May 13, 2012
- 28
Hello everyone,
So I have an otherwise clean 1998 Seaswirl Dual Console 2100 w/ 150 HP Evinrude Ocean Pro outboard. I'm experiencing the following issues:
- Stalling at idle
- Intermittent Check Engine light
- Intermittent Check Engine warning alarm
I understand this is an issue with the fuel system, however I'm not quite clear on how to diagnose or resolve it. I have removed and replaced the anti-syphon valve. I also checked the fuel bulb (disconnected and pumped some fuel into a jar to check for debris -- looked good).
Here's where it gets strange (which I hope will give clues to the problem). Sometimes if I start the motor, and I have a check engine light or alarm, I go squeeze the fuel bulb (its typically soft) until hard. This usually always gets rid of the alarm, and often the light.
Sometimes when I'm running at near WOT, I'll get the buzzer. I'll immediately throttle down, squeeze the bulb a few times, and the alarm goes off (again, sometimes the light as well).
Sometime when I refuel, or even start, I get no light or buzzer. Seems like a good refuel keeps both away for a bit.
Now on the stalling part, its odd how it cuts out. It will idle fine and then just choke (at which point it cuts down a few RPMS below normal). If I do nothing, it will choke again, even a few more lowered RPMS. If I don't squeeze or quickly throttle it will stall.
Once I couldn't get it to start for a while. I had to let it rest a bit. I may have flooded it.
So, with all this said, what areas should I check or consider? I'm hoping these symptoms indicate something obvious (and of course hopefully a quick fix). Thanks in advance!
- Stalling at idle
