Re: Ignition switch wire sizes and fuses
Its a Johnson 88 special, from the motor is about a 12 wire and there is a fuse in the motor I thought i would need an external 40 amp breaker between battery and
B terminal on switch. This is what I've came up with so far C terminal to choke from motor with 16 gauge wire, no fuse.
A for accessory with a 14 gauge wire for console accessories (not CD player) to a fuse panel with 10 amp fuse distributed from there to GPS/Fishfinder
VHF RADIO, and accessory 12 volt plug.
M (non raised) for ground with 12 gauge wire to battery ground.
B for battery positive with 12 gauge wire to battery positive no fuse?
M raised magneto ground for kill switch 16 gauge ground wire.
S for starter solenoid with 16 gauge wire connected to motor starter solenoid wire. Non fused
B to either fused or non fused is really the only question I have i think the wire sizes are pretty accurate.
I have a separate battery for my accessories courtesy lights, bilge pump, Livewell pump, horn, navigation/instrument lights and CD Player. I have these accessories on a switch panel all fused with individual grounds excluding instrument lights. My tilt and trim are harnessed with plug. Hard to get that one wrong. My other question is do I need a large fuse or breaker for my positive wire from battery to fuse panel i have an 6 gauge wire going to distribution fuse panel from battery.
