I was able to replace the impeller but now as I'm putting the lower unit back on, I have a problem with the shift linkage.
To get it off, I removed the R pin and pushed and the shift link came loose.
However, putting it back on, I can get the rod and the L shaped link bar connected but the shifter bar won't pull enough out to put the R pin back in.
Not sure if I have the shift rod in the right position.
In other words, I have it connected and working but I can't pull the L shaped rod out far enough to put the R pin in.
I don't want to force it.
Thanks for any suggestions.
