Re: 1990 60 hp johnson ignition problem
Well, I pulled the flywheel and the epoxy had melted and ran down the wires. The wires going into the stator feel flimsy, like they bend real easy. So I ordered a new stator, fingers crossed. Like I said in previous post, the resistance values were within limits, but only occasional voltage coming out of the stator. The problem started out only happening once in a while and gradually progressed to happening most of the time. Before I pulled the flywheel, it would start after cranking for a while, then only run for a few minutes before losing spark at all 3 coils. With a voltmeter connected, the voltage out of the stator would come and go.
