Does anyone know the torque values and sequence for an 80's 40 HP outboard motor
You wouldn't happen to know how the bolts are numbered would you. I know, If you the sequense then obviously you know the numbering.Thanks, Rick
The cylinder head has 10 bolts. They are numbered exactly as I have them listed. Start tightening with the center left (#1) nolt, then continue on in an ever widening circle.
