1991 johnson 200hp J200TXEIB ,
I just replaced the regulator/rectifier, stator,timer base, and powerpack due to the regulator shorting and catching fire. The engine runs great after you get it started. When I push the key in to choke in it stops the motor from spinning. I do not know if it was doing this prior to the electrical fire, because I never held the key in while spinning the engine. I thought you held the key in for 5-10 seconds before turning the engine over.
Any advice helpful.
Any advice helpful.
