Good afternoon all,
This is my first post and I have tried my best to make sure this isn't a repost. I spent a few hours looking through the site and found so much helpful information. Thanks to each of you for all of your hard work.
Background on my current issue. My grandfathers Terry Bass boat was given to me about five years ago but due to constant deployments I hadn't been able to use it. During this time I managed to misplace my key. When I returned home I attempted to put a momentary switch in for the starter and that was a complete failure. I quickly figured out I needed to go ahead and replace the ignition with a proper switch. I ordered the switch and it didn't arrive before I went back out. We had taken the remote controls out of the boat when we were trying to figure out the wiring (about two years ago) and now I have returned to the US and wanted to complete my project. Problem starts here......
1) I can not for the life of me remember where the alarm mounts inside the controls.
2) I can't get the controls back together. There is a spring with a metal ball that should kinda snap in place when I put the throttle back together but I can't figure out how to get everything lined back up to reassemble the controler. Is there a document or guide that might help me put this back together? The cam throttle and shift lever assembly also seem to be a bit tricky.
I should have taken pictures or video of us taking this apart but it is easy to say that after you've already screwed something up.
Any suggestions or help you might provide would be greatly apprechiated.
Regards
Sean
Regards
Sean
