randyray41
- May 31, 2011
- 123
I have a 1986 Evinrude 150 hp. Had boat out this weekend and all was running well. Then all of a sudden it quit, lost power. Would idle but when i gassed it it would die out. I checked to determine that the primer bulb was flattened out. I am thinking that the fuel filter may be stopped up? I even thought maybe the vent was plugged so I took cap off tank and still same thing.
Is it the filter or could the bulb be bad or could there be another problem. The filter is behind the bulb which leads me to believe its the filter.
Thanks for any input
