Motor runs good throughout RPM range(WOT 5600). Its idling in gear around 950(to high right?) any lower adjustment and it stalls. Did a link and sync when carbs were installed after cleaning them. Checked plugs and starboard side ones are dark tan and dry, port side ones are a little darker but with more oil like residue on them. Motor seems to have the "lean sneeze" at idle but not sure. Should I remove carbs and clean again?
