Moody Blue
- May 24, 2004
- 3,136
Recently bought this motor as a trolling motor. These models seem to be regarded quite highly so I hope it performs well. I have a few questions that I hope someone can answer. I plan on acquiring a manual but for now I'm relying on the members here.
1) The tiller throttle is VERY stiff. Can it be disassembled to clean and lube it? Appears to be a cable control.
2) Is there a general tune-up procedure available?
3) Compression test gave about 95PSI on each cylinder. Good or bad?
3) Is there an on-line manual available per chance?
Thanks to all.
Thanks to all.
