ReelReckless
- Jun 2, 2012
- 4
Been on iboats site a few times reading through the forums and every answer i was looking for, i found. But not really sure the direction to go in this time, so looking for a little help...since everyone on hear seems to know there stuff. Ok...here is the issue. I have a 1997 200hp Johnson Ocean Runner...toke the boat out last weekend and has some trouble starting it at the dock. Of course it started right up at the house the night before but in the water was a different story...usally is. I put the boat in the water...pumped the bulb til it was hard (and it seemed like it took forever for the bulb to get hard). Once the bulb was hard tried to crank it up and wouldn't start. When back to the bulb to check and the bulb was soft again. Pumped it for the second time and it wouldn't get hard. So a buddy of my pumped the bulb as i started the motor and it started right up. Let the motor warm up for a few before leaving the dock. Boat ran great out to the reef...no problem. Stopped and started the motor a few times moving around on the reef and it was fine. The end of the day went to fire motor to head home, it turned over but stalled...had to do a few time before it stayed running. Once was running, it did fine all the way back to the dock. Got home motor started up to flush no problem, but a lot of smoke. Finally had time again to get out on the water. Tried firing the boat at home and wont turn over, same issue with the bulb would get hard then soft. So, I pumped the bulb as the wife started the boat and fired up after a few turns of the key. Motor cut off twice before it stayed running, but again a lot smoke. Then motor started to stutter...so i had the wife kill the motor. So, now hear i am hoping one of pros on this site can give some info on my issue. Thanks.
