Crankcase Sealing - Loctite 518
emmo1210
Hi,
Could anyone confirm should Loctite 7649 primer be used along with Loctite 518 flange sealant when joining crankcase halves, or should 518 be used on its own? Motor is 90hp 1990.
Thanks all
Emmett
Joe Reeves
Re: Crankcase Sealing - Loctite 518
As long as the crankcase halves have been carefully cleaned of the old sealant, then wiped clean with either Lacquer Thinner or Acetone, one can safely use just the LocTite 518 sealant (GelSeal).
emmo1210
Thanks Joe,
Appreciate your quick response.
boobie
If you use the primer the 518 will set up faster. But who's in a hurry ? LOL
